Call of Duty Black Ops 2 problem [please help me]
Jackey Force
65
Hello, I have recently brought a game call 'call of duty black ops 2'. But when i play the game it crashes at every missions but not only on the 1st mission but somehow escaped from the some missions by download a save game of it, now i struck at the mission called 'Fallen Angel' and now how to recover from this problem. As i think the game is corrupted maybe or problem in my RAM or somewhere can anyone tell me what is the solution of the problem. Here is video to that problem, please please go to this link and watch this video and raise a comment or just answer here okay, please do...
My Computer specs ...::::...
CPU : Pentium(R) Dual Core G2020 2.90 GHz
RAM : 2GB DDR3 (1333MHz; form factor - DIMM)
GPU : HD Radeon 5450 2GB DDR3 Memory (with lastest driver installed of 6/12/2013)
OS : Microsoft(R) Windows(R) 8 Pro 32 - bit (with media center)
DISPLAY : iBALL 17' inch LED monitor
http://
______________________________________________________________________
OK PLEASE HELP ME MAIL ME ON : forcejackey@gmail.com
Simple solution. You need more RAM, because Windows 8 needs 1GB of RAM minimum, with 4GB being the recommended amount, and Black Ops 2 needs 2GB of RAM, with 3-4 GB recommended in order to play it properly. Because you barely have enough RAM to run Windows, when you run a game that requires more RAM than you have, the PC will run out of RAM and the game will crash. This means that you should go and purchase another 2GB 1333MHz RAM card, which will reduce your lag a bit, and prevent the game from crashing.
