'Ey up! I have a DSLR camera, It's really good apart from the power system. You see, it uses normal AA batteries like you'd find in a telly remote rather that the usual lithium ion rechargeable things you'd normally find in a DLSR camera. This is fine but it sucks power really quickly. So as soon as I put fresh, fully charged bateries in the camera and try to record some video, it lasts 2 seconds and then it says low battery. Annoying, right?
My question is can I find another way of supplying power to the camera, ethier by some sort of adapter or other means, to use it. And can it be done without frying itself?
UPDATE: a solution has been found. Thanks to everyone who posted 😀
