Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital,rec.photo.equipment (
More info?)
hope that yew enjoy it.
"Redd" <javatek?@usa.com> wrote in message
news:uKyBd.17875$6V1.11702@bignews3.bellsouth.net...
> Thanks you and the rest of the posters for replying. I decided
> to by the Kodak DX6490, more features for the buck. I got the
> camera, carrying case and 256m fast memory card all for
> US $389.00 delivered from BuyDig.com
> javatek?@usa.com
> remove the ? to reply.
> "Joseph Meehan" <sligojoe_Spamno@hotmail.com> wrote in message
> news:bRYyd.14160$LW1.5023@fe2.columbus.rr.com...
> Redd wrote:
>> I,m looking to buy a zoom digital camera. But am not sure what to
>> buy. I have narrowed to three cameras.
>> 1) Kodak dx6490
>> 2) Olympus C-765 UZ
>> 3) Panasonic DMC-FZ3
>> Three questions: Which is better shutter speed?
>> 1/1000,
>> 1/1700,
>> 1/2000
> The one that works for you. It looks like these are the fastest
> shutter
> speed for the cameras. The while faster is "better" the real life
> difference between the slowest 1/1,000 and the fastest is not all that
> much
> and you may never end up using even the 1/1,000 sec speed as long as you
> own
> the camera.
>> Olympus is only camera with manual focus. Is manual focus
>> something I really need?
> My guess is, since you had to ask, is no. I would miss it, but most
> users will never miss it and will either never use it or if they do, they
> would do better on auto.
>> The Panasonic is 3 megapixels while the other two are 4 megapixels.
>> Is that a beig deal ? From what I can tell that only effects the size
>> of the picture
>> and not picture quality.
> All else being equal the difference is not the size of the picture,
> they
> can all make the same size prints, but rather the quality of the results,
> especially for the larger size prints. However all else is never equal
> and
> the difference between 3 and 4 megapixels is noticeable it is not great.
> There are other quality factors that could overcome that difference.
> I don't have the link, but keep checking back, someone will give you
> the
> link to a web page that will detail the differences and should even show
> you
> some results from each.
> I suggest that before you buy that you take a real life look at the
> cameras. Hold it in your hands and see how it feels. That is a more
> important factor than most people think. If it does not fit it is not
> right
> for you.
>> Which one of the three should I buy.
> The one that works best for you.
> Joseph Meehan
> 26 + 6 = 1 It's Irish Math
