P Pankaj Bhalerao Prominent May 18, 2017 1 0 510 May 18, 2017 #1 I have 450w PSU and I want to work 300w graphics card on it and I have 6 GB RAM and 1 DVD writer and 2 fans and 500 GB HDD
Solution Supahos May 18, 2017 Absolutely not. Most CPUs and eco systems use well over 150w. And you really done want to exceed 80-85% of max PSU usage.
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 May 18, 2017 Solution #2 Absolutely not. Most CPUs and eco systems use well over 150w. And you really done want to exceed 80-85% of max PSU usage. Upvote 0 Downvote Solution
D dontlistentome Glorious Sep 5, 2016 5,987 26 43,440 May 18, 2017 #3 If the card itself requires 300W, I'd like to see the 450W PSU that even has the connectors for it! Are you sure you don't mean 300W is what the manufacturer recommends for the system that the card will be installed into? Upvote 0 Downvote
