I have a corsair H80i which has a 120mm radiator. However I am looking to get a new case which would be the Corsair 780T.
http://www.corsair.com/en/graphite-series-780t-full-tower-pc-case
Looking at the new case in the technical specifications, it says the following.
Technical specifications
Maximum GPU Length: 355mm
Maximum CPU Cooler Height: 200mm
Maximum PSU Length: 260mm
Radiator Mount Locations:
Front: 360mm or 280mm
Top: 360mm or 280mm
Bottom: 240mm
Rear: 140mm
So now I am wondering if it's okay to mount the 120mm radiator on the 140mm slot
Top: 360mm or 280mm
Bottom: 240mm
Rear: 140mm
