D dutch777 Reputable Mar 9, 2014 8 0 4,510 Mar 15, 2014 #1 I have a compact desktop whose PSU is rated at 220W. It is equipped with Intel G2020 (55W) and a standard HDD, DVD RW, etc. So can I add a graphics card such as Radeon R7 250 or GeForce GT 640 (both rated at 65W) and not worry about PSU failure?
Solution InvalidError Mar 15, 2014 A good ATX 2.3 spec PSU should be able to handle that fine. A not-so-good ATX 2.1 or earlier spec PSU, probably not as much. You could also consider a 750Ti - currently the best GPU under 75W.
5tormy Honorable Nov 12, 2013 30 0 10,530 Mar 15, 2014 #2 That's cutting it real close, possibly will run into issues. Can you upgrade the psu at all? at least a 300/350w? Edit: Is the psu a external brick? Upvote 0 Downvote
InvalidError Titan Moderator May 18, 2007 23,878 5,317 108,890 Mar 15, 2014 Solution #3 A good ATX 2.3 spec PSU should be able to handle that fine. A not-so-good ATX 2.1 or earlier spec PSU, probably not as much. You could also consider a 750Ti - currently the best GPU under 75W. Upvote 0 Downvote Solution
D dutch777 Reputable Mar 9, 2014 8 0 4,510 Mar 15, 2014 #4 It's a low profile card so my options are limited. The PSU is manufacturer by Acer and is featured in their Veriton compact series from last year. http://www.ebay.com/itm/New-Genuine-Acer-Veriton-X270-X275-X480G-X2110-Computer-Power-Supply-220-Watt/261341303580?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222003%26algo%3DSIC.FIT%26ao%3D1%26asc%3D20468%26meid%3D5497422098144920927%26pid%3D100005%26prg%3D9138%26rk%3D2%26rkt%3D6%26sd%3D270575222609&rt=nc Upvote 0 Downvote
