Can a 350 watt power supply work with a Geforce GTX 750 ti or do i need to find a less power consuming GPU?
ajaj895
7
I have a custom built computer with a 350 watt power supply, a Gigabyte AMD FX-4300 quad core processor, 4 GB memory, and 1 TB hard drive. The processor has a 95 watt requirement, and I don't know the power requirements for the other parts and fans. Would the Geforce GTX 750 ti work or do I need to upgrade my power supply or look for a less energy consuming GPU?
i wouldnt use it! as it'll be at its limit with the 750 ti needing 300 watt rating an cpu drawing 95 watts plus fans hd an dvd ect better go for a 500 or 650 watt they're cheap enough basically you would end up smoking that 350. hope it helps
