My PSU: https://www.coolermaster.com/catalog/legacy-products/power/v650s/
Specs as follow:
CPU : i5 11400
Mobo: Gigabyte B560M Aorus Pro AX
Graphic card: Gigabyte GTX970
I tend to use the CPU with no power limit. Will the Cooler Master V650 be able to handle the load? Or I should switch to a higher power PSU?
From what I read, the graphic card seems to draw ~290W at full load. The CPU seems to draw ~200W at full load with no power limit.
Thanks in advance!
Update: from the efficiency curve provided by Cooler Master. It seems that my PSU is able to keep 90% efficency at full load @230V. Which mean I'd have approximately 85watts to spare?
Specs as follow:
CPU : i5 11400
Thanks in advance!
