Can a CPU Water Block be used on a GPU?
DibDibs
22
Hi, I am currently shopping for a cheap, custom, water cooling system (preferably for >£100), and I was wondering if it would be at all possible to use a CPU water block to cool a GPU (Graphics Card), or, do I need a proper GPU cooler?
Thanks in advance, Aaron :)
Thanks for your answer, it's helped 😀
I guess I'll have to go with the expensive option...
The MSI GTX 980 Ti Sea Hawk uses an all-in-one CPU cooler, here contrasted with the EVGA Hybrid.
Quote:
The cooler’s layout underneath the shroud departs quite drastically from MSI’s Sea Hawk. Whereas MSI has used Corsair’s CPU-centric H55 AIO (basically Asetek’s 550LC), EVGA has decided to utilize a version of the GPU-specific Asetek 740LC. The visual differences between the two are minor at best but internally the 740LC has a contact plate specifically designed for GPU cores, something the H55 lacks due to its CPU cooling roots.
http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/70502-evga-gtx-980-ti-hybrid-review.html
one thing you might be able to try is making a hybrid cooler cut out a section of the reference cooler just large enough to expose the chip. you could then have a cpu block on the gpu and use the old cooler to keep the other chips cool.
