Can a desk lamp damage my monitor through heat?
guitarxe
222
I put a clamp-on little lamp on the top part of my monitor for reading at my desk, and I've noticed that it gets very hot around the lamp.
I'm concerned if this can damage my monitor?
It's attached to the plastic border of the monitor, and it only gets just warm.
But... I'm probably phrasing myself poorly.
These lamps they emit heat the same way as light, in a cone away from the lamp. So even though the clamp attached to the monitor is not getting hot my concern is that since part of it is shining at the monitor will that damage the screen.
For example, if I put my hand right in front of the lamp (not touching it) it gets uncomfortably hot pretty quickly.
