T TeZieh Reputable Mar 11, 2015 54 0 4,630 Sep 21, 2016 #1 Basically i want to purchase a gtx 1060, and the port on the back is a DVI-D while the port on my monitor is a DVI-I. So im wondering if i can just purchase a DVI-D cable and it will work? Thanks!
Solution clutchc Sep 21, 2016 Yes. The only difference between DVI-D and DVI-I is that DVI-I also carries analog signals for use with a DVI to VGA adapter.
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Sep 21, 2016 Solution #2 Yes. The only difference between DVI-D and DVI-I is that DVI-I also carries analog signals for use with a DVI to VGA adapter. Upvote 0 Downvote Solution
