Hi I checked out a review of the Zotac GTX 660 where it consumed only 202 watts maximum.
Also I checked out eXtremeVisions PSU calculator and it reccomended a 375 Watt PSU for the following config:
i7 4770k
GTX 660
Regular ATX Mobo
4 Sticks DDR3 Ram
2 HDD
1 DVD +/- RW
1 PCI card
1 PCI-e x1 Card
1 120MM LED Fan
1 80MM Fan
I have no intention of overclocking any part.
I also read on a separate forum that one individual was able to run his 660 GTX with an i5 2400 processor using the same PSU with ease. How much more wattage does the i7 4770k require?
The FSP saga does have a dual 12v rail setup (each rail has 17A on it, so combined amperage of the 12v rails is 34A, total power output on the two is about 336 Watts). It also has an 80% efficiency and according to tests 50% load gives about 79 % efficiency.
Given these facts what are the chanced that the FSP will die out burning the entire system to shreds, like an older (generic, cheap, chinese make) 300 Watt psu did when I plugged in a 9500gt into the system (with a pentium D processor).
So how do you think
i7 4770k
GTX 660
Regular ATX Mobo
4 Sticks DDR3 Ram
2 HDD
1 DVD +/- RW
1 PCI card
1 PCI-e x1 Card
1 120MM LED Fan
1 80MM Fan
So how do you think
