C cptzarkus May 6, 2018 10 0 10 May 16, 2018 #1 title says most of it can it also destroy the GPU ? my gpu : GTX 950
Solution S S sobok27 May 16, 2018 Yes, no machine is made to run at 100%. 70%-80% would be the sweet spot for longevity.
S sobok27 Distinguished Sep 10, 2011 45 0 18,540 May 16, 2018 Solution #2 Yes, no machine is made to run at 100%. 70%-80% would be the sweet spot for longevity. Upvote 0 Downvote Solution
derekullo Splendid Jan 25, 2009 2,896 493 22,190 May 16, 2018 #3 Dust to dust, ashes to ashes. Even a fan running at 0% (not running) will still fail given enough time. Leaving behind philosophy ... The key term here is the bearing type. https://en.wikipedia.org/wiki/Computer_fan#Bearing_types The bearing is how the fan blades are connected to the frame of the fan. With fluid bearings and magnetic bearings being the most reliable due to producing the least amount of friction, heat and wear between the fan and the motor. Upvote 1 Downvote
