C Chris Tran Reputable Jun 15, 2014 4 0 4,510 Sep 29, 2016 #1 I need to know if this cooler can fit in my spec-01 case, my T2 is breaking on me so I need to know if this cooler can fit
Solution Dark Lord of Tech Oct 1, 2016 It doesn't according to their own site and the H7 , I listed above is superior and fits.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,867 1,895 159,590 Sep 29, 2016 #2 No it won't fit cooler is 160mm , case only supports 150mm. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,867 1,895 159,590 Sep 29, 2016 #3 http://www.newegg.com/Product/Product.aspx?Item=9SIA85V4FU2360 Will fit and a better cooler , Cryorig H7 = 145mm. Upvote 0 Downvote
C Chris Tran Reputable Jun 15, 2014 4 0 4,510 Oct 1, 2016 #4 Thank you, I've been getting conflicting answers Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,867 1,895 159,590 Oct 1, 2016 Solution #5 It doesn't according to their own site and the H7 , I listed above is superior and fits. Upvote 0 Downvote Solution
