Archived from groups: alt.comp.hardware.homebuilt (More info?)
I have a machine I have been using as a test bed. I started
having hard disk drive failures, and finally realized this
motherboard might be the problem. At first, I thought cable
problems, etc. I finally tried the drives in other PCs, but they
still are displayed as failing by the powermax maxtor drive test
program, even after a low level format on one. Is it likely that
a motherboard problem could actually destroy the drives? Or, is
the damage recoverable? Is there a test program which can verify
proper motherboard disk controller operation?
Bob
Bob
