Hey all,
So I'm repairing a computer (Dell Inspiron 545 from 2009 or so) that had a bum hard drive. S.M.A.R.T. reported it was dying, and fortunately we were able to get the data off.
Replaced with with a WD Black 7200 RPM 1TB drive. The previous (failed) drive was a Samsung 640GB, also at 7200 RPM. I've tried both Windows 7 and the Dell drivers and Windows 10 with the default (Windows Update) drivers, and the issue remains the same...instability after a certain amount of time, up to a day, resulting in a blue screen. Otherwise, it works great...until that happens.
I've done 12 passes of Memtest 86+, the built in diagnostics, HD Tune hard drive diagnostics (which show the drive as perfect), and even several hours of HeavyLoad with no problem, but then it'll just crash idle. I've seen Memory Management errors as well as others (ACPI was one...there have been a few different ones at this point, some of which I was told about and haven't seen myself) I've also seen no signal to the monitor and it just hung.
The BIOS is fully updated. The BIOS SATA control is set to IDE mode; I may try RAID mode, but those are the only two choices available unfortunately.
I initially thought it was an issue with Windows 10 on this hardware (as it's not officially supported), but it's doing the same thing on a clean install of 7, and this was never an issue before the hard drive crash.
Is it possible this drive is somehow incompatible with this system, or is something else likely going on?
Thanks!
Thanks!
