R Rauldarlene 69 Prominent May 6, 2017 1 0 510 May 6, 2017 #1 Iam try to replace a power adapter cord. 19. 5. +(0)- output. To a compac loptop 18. 5vdc. - (0)+ input my question is why it wount charge when the light is show charching ?
Solution webworkings May 6, 2017 They need to be the same to work. Since it isn't, that is the problem. You need a charger cord that is the same as your original one.
webworkings Titan Apr 6, 2016 11,201 0 86,610 May 6, 2017 Solution #2 They need to be the same to work. Since it isn't, that is the problem. You need a charger cord that is the same as your original one. Upvote 0 Downvote Solution
