A friend gave me an unused 135mm x 25mm LY Evercool power supply replacement fan(which I don't need to use in my current power supply) and am wondering if I could use it on the back of my tower where the 92mm intake/exhaust case fan currently is? I have 3 other case fans installed(all are 200mm-one exhaust through the top, one in front and the other on the side panel-in my CoolerMaster Storm Sniper S) and that fourth one is 92mm on the back. The power supply fan has a black and red wire attached to the 3 prong motherboard clip(not molex) to go onto the motherboard. So, can I install it in the back without causing any problems? I thank you all for any responses.
