Can a refrigerator cause my 2.4 ghz connection to drop?
revolultrablue
253
I have my router ontop of a refrigerator. I understand this can interfere but can it cause the 2.4 ghz connection to completely drop? It's plugged into the same outlet as the fridge as well.
Since it is on top of the fridge, I wouldn't think the placement would block the signal or cause intermittent loss. Start up of the motor could cause a problem but not necessarily.
If you want to experiment with this, here's an idea. Run an extension cord to the router from an outlet on a different electrical circuit than the fridge is on. If that solves the problem, then try using a surge suppressor with good line conditioning on the same plug it is in now. If that solves the problem you are in good shape. If not, return the surge suppressor to the store and look for other causes or another location for the router.
Depending on how old your router is, you might also just replace it and see if a new one solves the problem...
The refrigerator will block and reflect signals which will cause many problems, but would probably be isolated to where you are receiving the signal.
Being plugged into the same outlet will cause electrical noise, especially when the compressor turns on and off.
This will be noticed as problems at random times, no matter where you are.
Depending on how old your router is, you might also just replace it and see if a new one solves the problem. If that doesn't help, then the problem was not likely in the old router. So, return the new one to the store.
There are many different reasons for intermittent dropouts and ping spikes such as cordless phones. So keep investigating until you find it. Some can be solved and others not. Sometimes it is as simple as changing the channel on the router. So try that too.
A refrigerator is not likely to interfere, other than possibly blocking or greatly attenuating signal in specific directions. Most likely sources of interference, at least in the 2.4GHz band, is wireless phones, microwave ovens and other access points on the same or overlapping channels.
