So my problem started a few months ago and my cpu fan failed so I used a replacement fan I had laying around to fix the issue and my pc works fine normally under normal operating conditions the error message I keep seeing is the BSOD page fault error so I thought it was failing ram or my cpu being to hot so I installed memtest86 and it showed my ram passed, I have 16 gb of ram btw, and an i7 920, so after that I checked my hard drives using the default windows tool and it said it was fine, so then I thought it was my cpu temp so I installed CPU-z and core temp and it stays around 49 C and 70 with a load, so that didn't help my issue so I assumed it could be the graphics card failing because in the past it's acted up, so I updated my drivers and downloaded MSI Afterburner and MSI Kombustor and found out my fan speed was only at 40 percent and my GOD was 70 C under normal operating conditions and that's when I found this site and read a few posts and decided to change my fan speed and increase it to 80 percent to cool down my GPU and I haven't encountered the problem again but I plan to stress my GPU with MSI Kombustor to try and produce the same results and figure out if it is my GPU failing, also one last thing my network adapter some times uninstalls it's self and I reboot my pc and the driver is back idk if that could be related but I though it may be relevant, mainly the only time I've noticed this happens is when I'm searching videos on YouTube and it BSOD when I'm watching a video but it freezes first, also it happened a few times while editing a video in Adobe after affects and the video windows went green like the video card was acting up then it BSOD.
I know this is a lot of stuff but any advice or help would be appreciated because I'm sort of clueless about pc's I'm just trying to figure out what the problem is so I can replace it and get back to video editing, thanks
I'll keep you guys updated if the increase fan speed helped and I plan to clean my pc case with air to get rid of any dust that could be in there
