Can a router provide 2.4ghz connection and 5ghz connection at the same time?
bumpz111
63
Hi, I have recently changed my wifi connection from 2.4ghz to 5ghz. My pc and phone work fine, however my printer can't access the network as it doesn't support 5ghz connection. Is there a way to set up the router so that my pc is connected to 5ghz connection but my printer is connected to 2.4ghz. I have a Virgin media super hub
hi
Which exact model of virgin super hub ,
2 or 3?
They should support both 2.4 & 5 GHz at the same time with different
SSID for each channel
If you have problems read the user guide
If that fails ask their technical support
Regards
Mike Barnes
I tried to, i can either set it to 2.4ghz or 5ghz, i cant find one that enables both
Typically there will be two different login options for your wifi.
Im not sure what you mean by that
As in, two different login ssid
Request a new superhub mate, you should have been offered one by now anyway
The 2&3 model are far far better, the sh 1 is absolutely abysmal for wireless signal , I had to use a secondary router with mine just to get an acceptable wireless signal downstairs & my house is not particularly large & has no solid internal walls...
Nobody should still be running the original superhub now , its hugely outdated
Yea, i have ordered super hub 3 should be here by Tuesday
Thanks
Good stuffmate, you'll be much happier - I drag 90mbs on 5g on a different floor to the router (never ever possible on the original model)
& activation is a automated phone call now instead of having to deal with an Indian(or even worse scottish ) call centre operative
