Can a sound card fix my issue.
reed71522
39
Recently I bought a p.c (custom made), it didnt come with the drivers installed so i got the drivers manually. Every driver worked on the pc except the audio one which was a realtek, it kept saying an error code whenever I tried getting it "Install Realtek HD Audio driver failure! [Error code 0x00000002]" I tried everything, looked everywhere, but nothing seemed to work leading to believe the integrated audio wont work. Can a sound card fix my issue? Can it restore the sound? My motherboard is a Gigabyte H67m d2 b3. And im running windows 10 64 Bit. Please help me!!!
Says file not specified 🙁
Have you tried the ones from the motherboard website ? you'll see at the very top by the title, there is 2 revisions of the board, make sure you get the correct revision first, also check that onboard audio isnt disabled in the bios.
https://www.gigabyte.com/Motherboard/GA-H67M-D2-B3-rev-10#support-dl
If Audio isnt working after that, id send the board back.
tried both and the guy i bought the pc from said the audio worked before he gave it to me, he reset the pc so does that have anything to do with the issue. And cant a sound card fix the audio?
OMG!!! How can you be so stupid, he is utterly lying... Give him back the mobo back...
Damn man, sadly lost his number been almost a month, should i upgrade the motherboard or get an audio card?
Ill just try the other one until I get enough money for the ASUS xonar Dx thanks for your help! Ill reply when I get the sound card and try it on. Crossing my fingers it works!
