Can a underpowered PSU cause low fps?
Mikoloco
319
Im having a really big problem, I have a GTX 650 ti which I bought recently to use on this gaming computer, and the problem is, im getting like 20-25 fps on games like Battlefield 2 (I do mean 2, not Battlefield 3 which would be understandable)
Not to mention that I was able to play Elder Scrolls V:Skyrim on ultra with my other GPU (HD 6770) with no lag at all.
Specs:
GPU:650 TI ASUS
CPU:Intel core duo E7500
RAM:6 GB RAM DDR2 333 MHZ
MOBO😛5N32-E SLI
PSU:LC POWER 450 W.
What could it possibly be then??
im really at an huge loss, I've tried everything, replace HDD, try other compatible mobo, only thing I haven't tried was to get a new CPU and MOBO and Ram aswell which would be pretty expensive because I can't afford it atm.
You can be fully sure. A faulty PSU will either output power outside the electrical standards (overvoltage/undervoltage) and cause ICs to power off, or it will overheat, possibly leading to a catastrophic end of all digital life around it.
If it runs other things normally, then that is an indication that the game itself is the source of the trouble. You should look at the settings to see if anything is really high. Also, you might have something in the Nvidia control panel overriding the game with higher settings than you specified in the game's controls. Before doing anything drastic, you should try the simple things, like resinstalling the game and your drivers (clean install). Use driver sweeper to help with that.
Yeah but im having this problem in all games except ironically CPU heavy games like Hearts of Iron😀arkest Hour, Hearts of Iron 3 and whatnot, in games like Skyrim with my HD 6770 I was able to play it at ultra for example at 45-50 fps steady and with this GTX 650 TI, I get like 20-25 fps max.
Hmm, that suggests it's software issue. Did you clone the drive to the new one, or did you fresh install Windows to start over?
Either way, I would suggest doing the driver sweeper, allowing it to reboot in safe mode first. Get that program here: http://www.guru3d.com/files_get/display_driver_uninstaller_download,9.html
Use it to remove all Intel, AMD, and Nvidia drivers. That will take three restarts, in safe mode each time. The program will automatically take you into safe mode when you start it if you let it.
Then do a fresh install of your Nvidia drivers.
The other HDD failed on me and I replaced it with the 160 GB one, I had to reinstall windows(and all drivers of course)
The drivers are all 10% updated.
It's really, really weird I never faced something such as this
That's really weird. Hmm. Try a few different things to rule out simple hardware stuff, which is essentially a stab in the dark at this point. But you can (1) switch around your RAM sticks into different slots and make sure they are seated properly, (2) put your GPU into another PCI-e slot, and (3) connect your HDD into a different e-SATA port on your motherboard using a different e-SATA cable.
If those things don't work, you might try another HDD, since your problem started after the swap. Sorry it's giving you such a hard time.
Alright, I had tried the RAM swapping earlier, while it got slightly faster it didn't work the fps remained the same, the p5n32e sli only has one blue slot to put the graphic card o
im going to try connecting the HDD into a different e-sata port, but with the same cable
Guys, I found the culprit, my CPU was underclocking itself, go to the bios and go to ''Overclocking'' and set the multiplier to 11x.
This afflicted me for months, now im able to play comfortably almost every game.
