Hello everyone,
Apologies in advance if this is a stupid question, I am not a networking expert.
I am trying to set up my home network ensuring that I have a strong wifi signal everywhere around the house. I have two ASUS routers (RT-AX92U and RT-AC68U). So I installed the RT-AX92U on the main floor as an AI mesh router and the RT-AC68U is on the second floor as an AI Mesh node. The node is using 5GHz and the signal is "GREAT" according to router web gui. However, since the node is connected to the mesh router wirelessly, the signal and wifi speed is very weak on the THIRD floor.
Now, on every floor, I have Ethernet ports that connect to the ISP modem. So I was wondering if there is a way to make both routers have a hard wired connection to the ISP modem (which is possible in my house since I have ethernet ports everywhere) and work together on the same network to boost WIFI WITHOUT having to connect both routers to each other with wire to enable Ethernet backhaul?
Appreciate your input!
