So I recently downloaded Dying Light, and I'm playing it on max settings and I've noticed a noise. At first I thought it was my power supply, but since realised it's my GPU. I've done a bit of research to see if anyone has had the same issue and I can't find anything other than coil whine but I'm not sure this is the same thing? I think this happened when I was playing AC Origins too.
If anyone could help me understand what this is, and if I should be worried that would be absolutely wonderful.
http://vimeo.com/275371178
Thank you in advance!
Kasey
Kasey
