Can anyone recommend a quality 1080p monitor (my TV looks way better than the ones I've tried)
Itachi_2
Commendable
Jul 16, 2016
18
My TV is a 2004 1080p Sony Bravia KDL-46V4100. I need a monitor that has similar quality and is just smaller. 21.5-24 inches is the screen size I'm looking for.
Try the semi-glossy Dell s2318hx, s2418hx. It's a great quality IPS with good colour uniformity. Light bleed varies between every monitor & I never noticed any but there was a little IPS glow in one corner which isn't noticeable in most situations (all IPS screens have IPS glow). Also it has better contrast ratio than any other IPS or TN screen. So blacks and dark scenes look stunning. Great colour accuracy. (At http://www.dell.com/en-us/shop/monitors-monitor-accessories/ar/4009?appliedRefinements=2829 Select the country at the bottom). On Ebay you can search for “VESA Mount Adapter for Dell”.
Latest posts
