[SOLVED] Can anyone recommend what power supply to use for this system?
Please note that PCPP offers both a wattage estimate as well as warning about the compatibility of your system based on mobo/CPU and possible BIOS issue.
Your best bet in regard to the PSU would be to select parts that are known compatible, take the wattage recommend, add to it a touch, and then see what is available in your price range. It is recommended to then do some review searches or look on some of the quality tiers available online to judge if it will be a good pick.
https://pcpartpicker.com/list/tJg79r
My budget for the power supply is 100$. I want to overclock the system to and the motherboard. And also give it a rating on a scale of 1-10 for a 920$ build
Hey there,
A decent 650w Gold unit would do you fine, but to allow for some overclocking and more power hungry components, maybe 700-750w.
My preference at the moment is the Corsair RMx/RMi/RM and even the TXm is pretty solid too (I have one with a 5600x and 3060ti).
Something like this:
PCPartPicker Part List
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($109.99 @ Newegg)
Total: $109.99
Generated by PCPartPicker 2022-11-01 11:12 EDT-0400
You cannot overclock with that system. Overclocking requires a K series chip, and a Z series board. That RTX 2060 is a bit overpriced. You can get a faster RX 6600, for less. For less than $10 more on the system total, you could step up to 32gb ram, and a 6650xt, with some parts changes.
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor ($193.99 @ Amazon)
CPU Cooler: Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler ($22.90 @ Amazon)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard ($109.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($89.97 @ Newegg)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($55.99 @ Newegg)
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card ($279.99 @ Newegg)
Case: Deepcool MATREXX 40 3FS MicroATX Mid Tower Case ($68.98 @ Newegg)
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($94.99 @ Newegg Sellers)
Total: $916.80
Generated by PCPartPicker 2022-11-01 12:50 EDT-0400
A 6650xt is just slightly faster than the regular 6600xt.
Latest posts
