[SOLVED] Can cold air damage computers and how cold does it need to be in order to cause permanent damage to pcs.
Depends on many factors, but cold is not going to be the primary issue.
The problem you are going to run into is condensation at low temperatures, that moisture will pose a greater threat than cold will.
Can you elaborate a bit more on the question here? That would help get some more solid answers.
Is this hypothetical limits? Is your PC next to a window in winter? Storage unit? etc.
Reactions: kurdtnz
