Question Can connect to internet through wifi, but not through ethernet cable, how to connect?
Feb 28, 2022
4
  • If I plug the cable in, the ethernet cable comes as an Unidentified Connection.
  • Ran troubleshooter reason comes = Doesn't have valid IP configuration
  • I manually typed in the IP address, still unidentified, later when I opened IP Config, the connection is still coming unidentified with an autoconfiguration ipv4 address instead of the ip address I put.
Feb 28, 2022
4
-I did that just now. But same results.
-Why does my laptop always take the wrong address in autoconfiguration ipv4 address?
Kopexx
7
Have you attempted uninstalling the nic from device manager and rescanning devices to set it back to default? Did you attempt to set a static IP to the machine from the router itself?
