Can I add another fan onto my CPU Cooler the Arctic Freezer A30 ?
DisoIsHere
28
Just a little idea i came across , is it possible to add another fan onto my CPU cooler , the Arctic Freezer A30 . The CPU cooler isnt designed to have 2 on it , but can add another on the other side . Will it help or just be pointless ?
Im asking because I have two Fans lying around and a couple of noise adapters. So I also want to know if i can put at least of the fans in my case to help with cooling ? excluding putting it on the side panel.
No need for a 2nd fan. Maybe 2 degrees cooler with 2 fans but NOT more then that.
It it just like with watercooling radiators.....Push/Pull only helps with thick fat rads or high PSI rads but with normal rads you only get 2 or 3 degrees difference....NOT more.
I have a Thanteks cpu cooler witch had 2 fans when I opened the box....I removed 1 of them before I installed the cooler and put the 2nd fan in the box for spare parts.
I have NO difference in temps :)
Just keep it in the box. The more fans.....the more louder your pc will be :)
(sorry for bad english)
