Hi i recently bought 4 120m fans on eBay assuming they were the standard 3 pin pwm. They have a 4 pin molex connector but only 2 wires running out of the fan to the molex connecter. Then there is another 4 pin molex running of the first (so you can chain all the fans together of a single molex). Is there a way i could change the 4 pin molex to a 3 pin pwm so i can buy a fan controller and connect it up. I haven't seen any 4 pin molex fan connecters and if there is there would be way to much cable mess for 4 fans. Thanks
