[SOLVED] Can i change my graphic card for a gtx 970? am i going to have problem with my system specs?'
Aug 29, 2019
8
Could i change my graphic card for a new one (gtx 970) if i have this specs?
Motherboard: p6td Deluxe edition
Processor: I7 x980 Extreme edition @3.33 Ghz
Ram: 24 GB DDR3 Triple channel NB frequency 2672.5 MHz
Graphic card: MSI GT 730 4GB DDR3
Power supply: ATX (500W) (fanatic , it came free with the case)
Is it going to fit in my motherboard? , if not , any recommendations? please help
Aug 29, 2019
8
I actually have....and am running...a P6T Deluxe with an i7-980 and a GTX 1080.
It should fit.
It should work.
I would get a new power supply.
hi , my power supply would support the graphics card or it would be some stressed?
what power supply do u have?
I think it may support it.
The reason I would get another one is....I think it's borderline.....and I'm thinking it's low quality.
In my opinion, when considering quality, the power supply is the most important component.
The power supply has the capability to ruin all of your other hardware if it fails in a certain way.
This is why I use a quality supply.
Right now, on my rig I am using a Corsair 750 RMx.
The Seasonic Focus is also a good series.
Reactions: MejiMOCO
Aug 29, 2019
8
yeah , it just came free with the case , any recommendations that you would give to me about a good and not expensive PSU?
anyways , thank you for helping me
You're welcome.
As I said....I went with the RMx....the Focus series is good.
I found this from a quick search of the forums.
PuperHacker
Jun 25, 2016992115,415197
Jun 29, 2019
Corsair CX550, CoolerMaster Masterwatt 550, EVGA B3 550.
You can't go wrong with any of them.
Reactions: MejiMOCO
