can i change windoes 7 64 bit Operating system to 32 bit Operating System And who
Roshan_9
Commendable
Aug 16, 2016
I am Install Windows-7 in my computer but it is in the 64 Bit operating System
how i Can Change it In Windows-7 32 Bit Operating System
Please
what You Can Give Me Suggestion Of This Problem
Agreed. 32-bit applications will run just fine on a 64-Bit OS, but 64-Bit applications will not run on a 32-Bit OS. Why do you want to make this change?
-Wolf sends
I'm not sure why you would want to install the 32 Bit version of windows 7, as the 64 Bit version is much better.
Unless there is a way around this, as in being able to choose while doing the installation, if not, you may or may not have to buy a 32 Bit version of Windows 7.
You can't just 'change it'. You have to do a full reinstall.
But why do you wish to change from 64bit to 32bit? There is almost never a good reason to do that.
