S suicidesheep1999 Prominent Oct 23, 2017 2 0 510 Oct 23, 2017 #1 So this is the setup I'm planning to construct. It is my first build and I'm on a real budget. I was thinking if I can combine AMD A8-9600 3.1GHz Quad-Core (with R7 on die) and GeForce GTX 1050 Ti 4GB for more power at gaming.
Solution Corwin65 Oct 23, 2017 You would be wasting money buying that APU and a GPU. Look for a better/newer build.
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Oct 23, 2017 #2 when the gpu will be the board will cut off the output on the internal to use the gpu . Upvote 0 Downvote
rgd1101 Don't Moderator Nov 7, 2011 74,861 4,244 176,290 Oct 23, 2017 #3 Short answer, NO. Upvote 0 Downvote
Corwin65 Illustrious Nov 2, 2015 3,590 153 37,090 Oct 23, 2017 Solution #4 You would be wasting money buying that APU and a GPU. Look for a better/newer build. Upvote 0 Downvote Solution
