[SOLVED] Can i connect a 4 pin to gpu using an adapter (4 pin to 8 pin)
Oct 29, 2019
4
so this is the 2x4 pin cables that my psu has. My gpu requires 8 pin but the other 4 pins is already connected to my mobo, so can i buy a 4 pin to 8 pin adaptor that looks like this. I have a 700w atx powerlogic psu. And i dont have enough money to buy a new one so can you please tell me if it can power up my gpu using that adaptor (second pic)
Mockingjason
Proper
May 22, 2019
125
9
115
8
I would never recommend that. Adaptors are NEVER a good idea, you have a somewhat high chance of the PSU destroying the GPU and maybe even everything it is connected to. Yes, adaptors work but it's risky. I would strongly suggest buying a new PSU
Reactions: Maxell163
Oct 29, 2019
4
Oh, thanks for your advice.
Since maybe I'll just get a new PSU, what would you recommend on buying, maybe a budget but decent psu would be great. :))
Specs:
Core i7 3770
Rx 570 sapphire pulse 8gb
8gb ram
500gb hdd
Msi h61m mobo
Thanks in advance!
Mockingjason
Proper
May 22, 2019
125
9
115
8
Specs:
Core i7 3770
8gb ram
500gb hdd
Msi h61m mobo
Thanks in advance!
what is your budget? how much can you spend?
