can i connect a 4pin AND a 3pin fan in the same header using a Y splitter?
boknoykatok
14
my case accommodates 3 120mm fans. motherboard has cpu fan header, another 4pin header and a 3pin header.
the cpu header and 3pin header is used by the aio liquid cooler (fan&pump). leaving me only 1 4pin header to use for other fans.
my 2 other fans are different. 1 is pwm, while the other is 3pin.
can i connect them both using a Y splitter to the 4pin header? can i control its speed?
thanks! tried it today and it worked!
Really glad to hear that. Happy to be of help buddy...
