Question Can i connect an RGB fans cable to an rgb light strip header on the mobo?
May 16, 2019
So im planing to buy the Motherboard ATX Gigabyte Z390 UD but im not sure if i can connect the rgb fans on the Nox Hummer TG Case to the rgb led strip connector on the mobo.
Jan 5, 2019
126
16
195
4
Yeah that shouldnt be a problem, worst case just get a fan controller. But the Z390 has a few RGB headers so you should be all set to just plug in your fans and use your MoBo Software to utilize the different light funtions (if available) for your RGB.
Similar threads
