Can I connect by Bluetooth to my Creative Sound Blaster Audigy FX 5.1 PCIe Sound Card ?
Ronshere
50
Hi
I would like to use my Soundblaster to play music with my Bluetooth speakers but what is happening is the sound seems to come through my motherboards audio instead (and it is not great). The Soundblaster says no speakers are present, connect to enable and so on.
Is there some way I can use the soundcard with Bluetooth?
I have a USB Bluetooth adapter plugged in to my PC.
The USB BT adapter is plugged into the mobo so that's the audio it gets..
You can connect a BT transmitter to the Soundblaster audio output and pair that with the speaker.
If you are concerned with sound quality a wired connection will be superior.
