Hello... Your Power supply has 5 volt and 12 volt power for Fans... But your Fans will run at one speed only, and you can get a 12vdc fan to run at about half the speed using the 5 volt power... this keeps them nice and quiet as a "Quiet PC" option.
The PCI-E connector will have +12vdc and GND Pins available... But do not just plug your FANs into a plug without really knowing how the plug is wired... take off the cover of your PS housing and Look.
Yellow wires are +12Vdc
Red Wires are +5Vdc
Black is common/GND
Pins in a Plug can be removed from the back, using, finding, the metal tang on the PIN to "unlatch it" ( push-in tang )... then you can move The Pins/Wires around to match the Plug on your Power supply.
There are 2-wire, 3-wire...
