Can I connect my led strip to my 9 pin usb on mobo?
Jan 1, 2019
4
I wanted to know if I made a connector for the 5v/ground only on USB 9 pin header would it power my RGB light strip. Just wanted to keep the wiring to a minimum in my case.
Ah those are the ones with addressable RGB with normal USB-A plug ? That should work but needs software to control colors. Those USBs on MB are no different than ones behind the MB. You don't even need all 9 pins, only four in one row as they give one full channel. One extra pin in one row is not connected to anything.
