Question Can I connect my molex fans to my pwm fan's daisy chain?
Aug 21, 2020
So I have 2 molex fans and my pwm fan came with PST or daisy chain. Can I do at least voltage control if I coonect my 4 pin molex fan to this?
Aug 21, 2020
You probably need to make the connector yourself. Either by soldering or use cable lugs (not sure that is the correct english term for the clamping variant for just connect two wires together).
can't I use a simple molex to 3 pin adapter?
