Can i extend my 24pin cable DIY.
usmansajidrocks
64
So i couldnt find any connector to extend cable so i thought i cut a 24pin from other psu and cut this one extend it by 4-6inches.
Will it work?
What should i be carefull about?
i wont do it my self. I will take to a shop where they solder and do stuff.
Why not just buy a 24-pin extension cable? Cutting 48 wires, stripping 96 wire ends, soldering 48 joints and covering them up is going to take a while, which means non-trivial labor cost. You can probably find ATX extension cables for less than $10 if you look around a bit.
