Can I fit a 6+2 pin into an 8 pin connector?
6+2 pins is a 6 pin connector with an optional 2 pin that can be clipped into place.
This means it can act as a 6 pin, or an 8 pin. It will work with both.
^+2
The PCI-E power connectors are designed specifically for the PCI-E graphic cards. If the graphic card has a PCI-E 6-pin, then that cable or the 6-pin on a 6+2pin PCI-E power cable from the power supply will work. If the graphics card has a PCI-E 8-pin power connector, then an 6+2pin PCI-E cable (with the +2 attached) will fit and work with your graphics card.
-Wolf sends
