Can I fit a MATX Motherboard in a ATX Case.
ICallHax
27
Hi guys
So I know you get this question a lot however I need a specific answer on this if possible.
I have a school project in which I am making a VERY cheap build.
I was wondering if I can get this mobo http://
and fit it in this case http://
Thanks
If possible, please put your entire question in the body of the post next time. :)
Yes a micro atx mobo can fit in an ATX case for the most part. Look at the specs to make sure it will work because there are some atx cases that don't support anything smaller (or larger) than ATX.
Thanks I accidentally posted it too early however I updated it with the links. If you want to take a look.
