V valeriu_rusu May 14, 2018 5 0 10 May 14, 2018 #1 I have an i7 6700k his temp is 80deegre i want a new cooler but i dont know if i can fit a water one . If it is air cooler max H 160mm
Solution Saturnity May 17, 2018 valeriu_rusu : Saturnity : According to the specs, yes, because that is a 240mm I have i7 6700K GTX 1070 16 ram Motherboard Asus Z170 gaming No I meant the case specs haha. Yeah you can fit that cooler though in that case don't worry
Saturnity Distinguished Jan 11, 2017 523 0 19,210 May 14, 2018 #2 Yes you can fit a water cooler. I believe the max is 240mm. Upvote 0 Downvote
V valeriu_rusu May 14, 2018 5 0 10 May 15, 2018 #4 DeepCool CAPTAIN 240 EX RGB Can i fit that ? Upvote 0 Downvote
Saturnity Distinguished Jan 11, 2017 523 0 19,210 May 15, 2018 #5 According to the specs, yes, because that is a 240mm Upvote 0 Downvote
V valeriu_rusu May 14, 2018 5 0 10 May 16, 2018 #6 Saturnity : According to the specs, yes, because that is a 240mm I have i7 6700K GTX 1070 16 ram Motherboard Asus Z170 gaming Upvote 0 Downvote
Saturnity Distinguished Jan 11, 2017 523 0 19,210 May 17, 2018 Solution #7 valeriu_rusu : Saturnity : According to the specs, yes, because that is a 240mm I have i7 6700K GTX 1070 16 ram Motherboard Asus Z170 gaming No I meant the case specs haha. Yeah you can fit that cooler though in that case don't worry Upvote 0 Downvote Solution
