Can I fix this motherboard hardware problem?
G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.periphs,microsoft.public.windowsxp.hardware (More info?)
Hi,
This is a pic of a new motherboard I've got hold of where the 'lugs'
which the CPU heatsink fit on to have been damaged:
http://members.aol.com/jorolat/sempronlugs.jpg
I've been able to fit the heatsink/fan assembly & it works OK with the
CPU temperature running at 46/47 degrees C (according to Speedfan).
I've been thinking of adding a dab of a non-permanent thread locker to
the broken lugs/heatsink clip such as the one shown here:
http://www.wheelspinmodels.co.uk/shop.php?item=1762
Would this be a good idea - or has anyone got any further suggestions?
Thanks!
John Latter
Model of an Internal Evolutionary Mechanism (based on an extension to homeostasis) linking Stationary-Phase Mutations to the Baldwin Effect.
http://members.aol.com/jorolat/TEM.html
'Where Darwin meets Lamarck?' Discussion Egroup
http://groups.yahoo.com/group/evomech
I think that you're SOL... That board doesn't have any mounting holes for
alternative heatsink mounting.
Since the chip is so close to the edge of the board, you MIGHT be able to
rig some kind of clamp on the one side, but you'll need to be careful.
Thread locker won't hold anything... I don't even think that you could
superglue the broken lugs back into place and have them hold.
Something you CAN do is the following... BUT IT IS PERMANENT. Make sure you
choose a good, reliable heatsink. Get some Arctic Silver EPOXY. Clean the
CPU very very well. Apply a dab of the epoxy and press the heatsink onto the
chip. Keep them tight until the epoxy sets.
This is ADHESIVE and NOT the normal Arctic Silver compound you normally use
on a CPU... See here:
http://www.arcticsilver.com/arctic_silver_thermal_adhesive.htm
"Noozer" <dont.spam@me.here> wrote in message
news:xOmRe.346034$s54.168704@pd7tw2no...
> you choose a good, reliable heatsink. Get some Arctic Silver EPOXY. Clean
> the CPU very very well. Apply a dab of the epoxy and press the heatsink
> onto the chip. Keep them tight until the epoxy sets.
> use on a CPU... See here:
One thing to keep in mind with this approach is that you're adhering the
heatsink to the CPU, but then there's not much holding the whole assembly to
the motherboard. Well, there's that latch, but if the heatsink is heavy, you
may end up pulling the CPU out of the socket. Not to mention the stress on
the CPU itself from the heatsink pulling on it. If you can run the computer
so that the motherboard is flat, you won't have that problem. I've done
stranger things than this...
That is a brilliant picture of how not to apply thermal paste!
Andy
"Andrew" <andrewportess@nospamhotmail.com> wrote in message
news:11hc625mp731uff@corp.supernews.com...
> Andy
You are absolutely tight...there is enough paste on that puppy for a dozen
CPUs.
Bobby
Thanks for the advice Noozer. Since sending the OP I've been looking
on eBay & the cost of a new board is quite reasonable. I'll either
leave things as they are or get a new board - its an el cheapo PC
Chips M863G.
John Latter
On Wed, 31 Aug 2005 21:49:29 +0100, "Andrew"
>Andy
Thats interesting Andy cos I don't know much about this stuff - what
you see in the pic was how much paste was there when the unit arrived.
Now that its working I'm reluctant to take the heatsink off again. Is
there a downside to having that much paste on there?
John Latter
i'd recommend a new motherboard altogether rather than risk crushing
the cpu die.. it is very easy to crush the cpu die, heatsinks with the
metal bars that clamp it down are designed so that when the pressure
comes down it it completely horizontal, if you were to put pressure on
it yourself you could risk crushing the cpu.
having that much thermal paste is not a bad thing, it doesn't do
anything bad.. actually the more you put on it cpu the less chance of
you not putting enough and risk frying the cpu.
also if you're gonna put the heatsink back onto that paste.. well
don't.
you have to clean that paste off and put some new paste on.
John Latter wrote:
> Hi,
> Thanks!
> John Latter
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
On Wed, 31 Aug 2005 19:28:34 +0100, John Latter
<jorolat@tiscali.co.uk> wrote:
>Hi,
>Thanks!
Please ask in a different group. Your question has nothing to do with
WinXP and hardware.
cripes. i'd toss that out and look for something a *lot* better if i stooped
to ebay (ie 2nd hand).
i do realise $20 is a lot for some...
> Chips M863G.
On 1 Sep 2005 12:29:00 -0700, "larry moe 'n curly"
<larrymoencurly@my-deja.com> wrote:
<snip>
> Also
>those lug holes often have sharp edges that can cut through the
>plastic, so I file them smooth at a 45 degree angle.
LOL, I thought I was the only one who had ever done that!
>don't.
oops - I've already put the heatsink onto the old paste & have been
running the unit... 'gulp'
er, I know I could probably find out on google, but as I'm already
here, do I just wipe the old stuff off?
>John Latter wrote:
>> Hi,
>> Thanks!
>> John Latter
John Latter
>>Hi,
>>Thanks!
>WinXP and hardware.
has too
John Latter
On Fri, 02 Sep 2005 05:54:01 +0100, John Latter
>>>Hi,
>>>Thanks!
>>WinXP and hardware.
>has too
What are you, five years old? "Has too?" Is that the best rebuke you
could come up with?
You mainboard damage has NOTHING to do with XP.
"NobodyMan" <none@none.net> wrote in message
news:agrhh1tc88i0k8osfnltns98l2t7562h5c@4ax.com...
>>>>Hi,
>>>>Thanks!
>>>WinXP and hardware.
>>has too
> could come up with?
But it has something to do with hardware. This group's sign on the door, Ms
Net Nanny, is microsoft.public.windowsxp.HARDWARE.
Alias
>>>>Hi,
>>>>Thanks!
>>>WinXP and hardware.
>>has too
>could come up with?
Why waste ink...
John Latter
On Sat, 3 Sep 2005 02:38:45 +0200, "Alias"
>>>>>Hi,
>>>>>Thanks!
>>>>WinXP and hardware.
>>>has too
>> could come up with?
>Alias
Thanks Alias - 's wot I thought too!
John Latter
>>>>>Hi,
>>>>>Thanks!
>>>>WinXP and hardware.
>>>has too
>> could come up with?
>Alias
Yes. That means it is open to questions regarding hardware problems
that relate to the XP Operating System. Now explain to me, Ms.
Dumbass, how damage to the mainboard relates, in any way, to the OS.
but it is a common enough problem for h/w that xp does run on.
get a life.
news:aoikh151mq09t9m2iprgqpo16oseih5ka0@4ax.com...
>>>>>>Hi,
>>>>>>Thanks!
>>>>>WinXP and hardware.
>>>>has too
>>> could come up with?
>>Ms
>>Alias
Bullsh*t.
No need.
Alias
> >Andy
> John Latter
yeah, major downside. failure. CPu getting too hot. I don't know the
science, but
, it onyl works properly when there's a thin layer of arctic silver
paste over the core(that rectangular or square thing in the center of
the processor). The layer should be very thin, e.g. smoothed out with a
razer blade. You have to be careful about applying it. don't touch it
with your fingers.
The arctic silver website has instructions on how to apply it.
Regarding cleaning it off and reapplying, I use the same safe method
I use when cleaning thermal pads off heatsinks or CPU cores. Maybe you
have to use this method even with paste. 99% isopropyl alcohol and a
lint free cloth.
To get the 99% IPA. (at least in the UK) You go to a chemist (a real
one,not a big store). And then, you ask for the chemist (he's gotta be
wearing a white coat). And you ask him for it. He should give it to
you. IF he asks then tell him it's for cleaning. Most *Real Chemists*
will be fine with it. It's not always easy to find a real one.
Sometimes you ask for one and a guy in a suit comes out and tries to
sell you some 50% solution of something.
Don't think of drinking it, that 1% of isopropyl can cause brain
damage. It's not Ethanol. I also, only use it outside 'cos i've read
that it's nto good to inhale or get on skin - so I wear plastioc
gloves. (Though a scneitist friend says it's ok to inhale a bit or get
a bit on the skin, he uses it all the time and it's one of the safer
things in his science lab!)
get lint free cloth. Regarding what it is..! Lint is bits of thread.
So a tissue, if you wet it and rub it on your trousers, would shred a
bit. THose shreds are called lint. any shreds are called lint. You
want a cloth that doesn't disintegrate like that. Jiff Cloths are a
brand name in the uk. Or immitation jiff cloths. Or those cloths for
cleaning lens on glasses.
A Razer blade for thinning the paste over the core.
Clean the heatsink adn the cpu.
Alternatively, you could just get a thermal pad. but they are not as
effective at cooling. You still have to go through the whole cleaning
job though.
Regarding the 99% IPA. THereare alternatives. But some have drabacks.
AKASA(a company of whome I bought a heatsinks that broke AMD
specifications!!) make a fluid for cleaning CPUs. So I would avoid
that. And some people talk of using Acetone. But apparently if you get
that outside the core of the CPU, it'll go through the CPU or burn it,
so forget that. 99% IPA is the proper stuff. If you cant' get
that, then maybe AKASA's fluid. But if you can even get 99% IPA in the
UK, (with some difficulty , talent and technique) you can get it
anywhere!
> >Andy
> John Latter
science, but
with your fingers.
lint free cloth.
job though.
anywhere!
> >Andy
> John Latter
science, but
with your fingers.
lint free cloth.
job though.
anywhere!
>> >Andy
>> John Latter
>science, but
>with your fingers.
>lint free cloth.
>job though.
>anywhere!
Thankyou very much James!
John Latter
