Can i get a different model cpu fan than stock?
AmandaEscareno
4
Hello,
Im trying to upgrade the cpu fan in my computer but im worried about the little hook-up where you plug the fan into the computer. Is there a way to get a fan I want and still plug it in to the computer????
It will either be a 3 pin or 4 pin connector on the motherboard. If I'm understanding you correctly, I'd say that what is on you motherboard is 3 pin.
