Touching the ground itself is supposed to be the surest way to be grounded when building/fixing a pc, but obviously building your computer outside is not much of option. I know there are static bracelets ect. but I’m curious.
What do you guys think would happen if you took a copper wire, buried one end in the dirt outside a window and wrapped the other end around your ankle? (Obviously you would NOT plug your power supply in/ turn on or fiddle with any plugged in electronic devices while doing this)
Would you be safely grounded?
Would you need to run another wire out of the dirt to your case too?
Could you get electrocuted using your (not plugged in smart phone??)
Not saying this what I am planning to do when I build a pc, just wondered why no else seems to have tried it yet. I know it sounds a bit in convenient but it does seem the most simple and surefire way to keep yourself grounded.
So would this work do you think?
