Can I have two fans on the radiator? One front side of the radiator and the other on the back side? Both in same direction.
lokeshclr
40
Hi
I have 2 fans one in front of the radiator of liquid cooler and the other behind it. Both the air flows are in the same direction. Is it the same thing as Push +Pull type of air flow?
I'm assuming that the radiator manufacturer has a spec for the minimum airflow needed to operate the radiator efficiently. I'm also assuming that there's a maximum airflow, too (may or may not be spec'ed). Too high of airflow may impede the transfer of heat from the radiator to the air. Think of it this way. If you stand in front of fan at medium speed, it cools you off. If you crank the fan to max, you feel more airflow, but it doesn't cool you off any more than medium speed. My point is that depending on the design of the radiator, 2 fans may reduce it's efficiency.
Is it efficient that way or should i remove one fan place at some other location
Your answer explains up to some extent, but not exactly to the point. Thank you.
But two fan combo was making so much noise . I had to remove one fan from that combo.
