I have a BioStar A770E3 board with a 4pin CPU connector, I also installed a Corsair H60 Watercooler and the fan is NOISY (idk why) for it. I want to use my Cooler Master fan with my cooler but its only a 3pin connector. The manual says that the 4th pin is for SmartFan Control, is this needed? Can I plug my 3pin in to the 4pin? is there any possibility to rig my Cooler Master to the water cooler?
Thank you!
Thank you!
